It is currently Sat Aug 09, 2025 10:35 pm
 Post subject: bridge plate size
PostPosted: Fri Jan 20, 2017 7:50 pm
First name: Thomey
Last Name: Dertien
City: Sioux Falls
State: SD
Zip/Postal Code: 57106
i just got done watching Kent Everetts dvd set on voiceing and he said to make the bridge plate 1/8 thick 2" wide. I have always followed my plans and the bridge plate on my plans is 2 1/2" and my bridge is only 1 7/16" which is a half inch bigger on front and back of the bridge. this is a grand auditorium and i forgot what body size he was talking about but prettry sure it was an om. does anyone know why its so big on my plans.
 Post subject: Re: bridge plate size
PostPosted: Fri Jan 20, 2017 8:23 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
I had to read that three times to make out what you are saying.
You might want to edit your post to make sure that when you are talking about the bridge you say "bridge" , and when you are talking about the "bridge plate", you say "bridge plate"
PostPosted: Fri Jan 20, 2017 8:40 pm
First name: Thomey
Last Name: Dertien
City: Sioux Falls
State: SD
thanks, yeah that didn't make sense at all.
PostPosted: Fri Jan 20, 2017 9:01 pm
"does anyone know why its so big on my plans."
The size of the bridge plate was increased when it became popular to use heavier strings on flat tops. It helped reduce warranty work at the expense of the sound. If you use a nice wide, thick, stiff, heavier one you will get less "bellying " behind the bridge. If you use the one Everett suggests you may get a more responsive instrument.
PostPosted: Fri Jan 20, 2017 11:29 pm
First name: Thomey
Last Name: Dertien
City: Sioux Falls
State: SD
I've read quit a few post saying the bridge plate should be 1/8 wider than the bridge front and back. That would make my bridge plate 1 3/4" would that be to small?
PostPosted: Sat Jan 21, 2017 9:57 am
I would follow Everett's suggestion and make it 2 inches wide and use a lighter wood like maple. I would put the extra width in the back. It will give you a little more support and a little more wiggle room for placing the bridge pins. When in doubt erring toward the middle (of suggested values) might not be a bad thing.
PostPosted: Fri Jan 27, 2017 11:19 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
Quote:
That would make my bridge plate 1 3/4" would that be too small?
Not in my opinion. I make all my bridgeplates 1 3/8" wide when I use a belly bridge (which is 1.4" wide). It was good enough for Martin from 1932 until 1968. The bridgeplate should be centered under the bridge, not offset to the rear.
These users thanked the author John Arnold for the post: Ken Jones (Sat Jan 28, 2017 11:57 pm)
PostPosted: Sat Jan 28, 2017 1:30 am
My bridge plates are usually bigger than that.
I know that Kent does not endorse curved bridge plates or 'smiley faced bridges' however, I feel that Trevor Gore has a much more factual base, and he does.
IIRC, he suggests a curved bridge plate extending 20mm past the end of the bridge. It's been a long time since I had my nose in those books so look for yourself for actual facts...
Having said that, I noticed an immediate improvement in my guitars using a curved bridge plate. Without a localized stress riser incurred with a straight edged bridge plate, one can make both the top and bracing lighter without experiencing bridge roll. Of course that's just one ingredient in an entire system and I don't mean to suggest that a curved bridge plate by itself is a problem solver, just saying that in conjunction with a host of other things, it can be a good thing.
These users thanked the author meddlingfool for the post: Pmaj7 (Sun Jan 29, 2017 2:48 pm)
PostPosted: Sat Jan 28, 2017 1:34 pm
I think as people gain experience evaluating the quality of the top and making adjustments for it, the size of the bridge plate usually goes down. A nice stiff red spruce top can use a smaller plate than a floppy Engelmann top.
You don't want too big of a bridge plate, but assuming you are relatively new to guitar building (less experienced), taking the middle ground might not be a bad thing. On a couple of my early guitars I missed the bridge plate with the bridge pin holes (half on half off) - not a good thing! A slightly wider plate (or better precision) would have helped.
These users thanked the author Clay S. for the post: nathanpeirson (Sat Jan 28, 2017 4:36 pm)
PostPosted: Sat Jan 28, 2017 1:52 pm
I make bridge plates as small as possible. 1/8th seems a bit too thick to me. I go 3/32nd on mine. But you know to each their own. It seems to me that a curved line along the back edge of the plate is a good idea. As a responsive guitar gets older it tends to telegraph more, a visual representation of the load, and the curved lines on the bridge plate and the tail block seems like it would spread that out imo. I have not done curved plates yet but have seriously given it some consideration.
PostPosted: Sat Jan 28, 2017 2:07 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
No argument from me about the bridge plate, but where does the tail block enter into the equation? Nobody these days makes the gluing surface of the tail block any wider than the kerfed lining, surely ?
PostPosted: Sat Jan 28, 2017 2:28 pm
Nope, we sand a bevel in it so it matches the lining width.
PostPosted: Sun Jan 29, 2017 12:00 pm
I still make the tail block the traditional way. I probably should taper it though, it's a good idea.
PostPosted: Sun Jan 29, 2017 9:17 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
I'm assuming that a thin-ish bridge plate with an aluminum 'plate mate' on the bottom to take the thrashing from the string ends would be a good thing to do. Easy for us home builders to take that extra step, not so appealing to manufacturers who see extra steps for hidden work as not profitable.
Peter Havriluk
These users thanked the author phavriluk for the post: sulcata (Mon Jan 30, 2017 10:03 pm)
PostPosted: Mon Jan 30, 2017 7:44 am
If the bridge plate is made of the right wood and slotted for un-slotted pins then adding an aluminum plate will not be necessary.
